Hi all,
First time self-build gaming rig here. Got my system all set up last week and everything was great, but a couple of days ago started getting BSODs on certain games (and sometimes just browsing on Chrome).
These are the stats:
MB: Z390 AORUS PRO WIFI
CPU: i5-9600K at factory clock speed
RAM: 4 x 8GB Corsair 2400Mhz RAM
GPU: GeForce GTX 1070
Storage: 2 x Crucial M.2 1TB SSD
PSU: Corsair TX650M 80+ Gold Semi Modular Power
I've updated all drivers and the BIOS and run memtest which passed without exception. I also run a userbenchmark test and it passed with flying colours.
It may be a coincidence, but this only started happening after I had problems with my integrated wifi controller, which I eventually fixed.
The system has never really run under stress, and temps are all good from what I can see.
The BSOD code is MACHINE_CHECK_EXCEPTION, so assuming it's a hardware problem. Regardless, I've tried a fresh installation of Windows, but can still reproduce the problem consistently. I've also tried many different RAM combinations, but each has the same outcome.
The GPU is second hand from a mate of mine who never had any problems with it.
Since I started the troubleshooting process, I checked my ************ list again, and noticed a compatibility note which I'd previously missed. Apparently my MB has an additional 4-pin ATX socket in order to recieve an additional 12v, but my PSU doesn't have that connector. According to another forum, that's unlikely to be a problem unless I start trying to massively overclock, which I'm not planning on doing.
Weirdly, I've also notice my second M.2 SSD isn't showing in Windows Explorer, but it's definitely present when I open up diskpart. Is there something I need to do to enable it?
Any thoughts?
Thanks,
Kohota
Any thoughts?
Thanks,
Kohota
