I've spent an ungodly amount of time researching the various bits and bobs involved in my most recent build, charts from Tom's Hardware, ***** review, OcUK forum advice etc etc etc. After a mad night, which saw me in bed for 3am, I've picked out all the components I should need and I'm ready to buy.
I don't really need a full spec, just a once over and if you spot anything erroneous just shout
The areas I'm most open to change on are the PSU (550W + cheap) and the case - I'm torn between the CM Storm Scout and a NZXT Guardian 921, I'd prefer a blue case and the temperature readouts are handy but I'm unsure of it's coolng credentials - it's well-reviewed but the Scout is widely regarded as a brilliant cooling box.
On to the system then:
CPU: Core i5-750
GPU: Sapphire HD4890 Vapor-X 1Gb
RAM: G.Skill 7-7-7-24 @ 1600MHz
MOBO: ASUS P7P55D Pro
HDD: Hitachi 500Gb 7,200rpm 16Mb
Case: NZXT Guardian 921/CM Scout Storm
PSU:Silverstone Strider 500W
CPU cooler:AC Freezer 7 Pro R2
Optical Drive:Sony 22x DVD+-RW
Windows 7: 64-bit Premium
Total: £731
I'm planning on buying a 1900x1080Monitor: Viewsonic VX2260WM £135 once the bank balance is a little improved and I'll probably throw in a 2nd HDD too. As you can probably tell I'm on a middling budget and don't really want to exceed £750, if I was to spend the extra £20 I'd probably improve the PSU so I can drop in a 2nd 4890 when/if the price drops. The main use of the rig will be for gaming, particularly running 2-3 copies of EVE Online, RTS and FPS' once I get round to buying a few, I'm not too fussed about the synthetic performance of any of the parts, it's mostly the overall FPS I'm interested in.
Perhaps this: Be Quiet! StraightPower 600W @ £63. If anyone could show me a 6-700W modular PSU around £60 which isn't based on an Epsilon FSP that'd be fantatstic. I know the 550W can power the current system but I'd like the PSU to survive a few upgrades.
Cheers,
Cyrl
The areas I'm most open to change on are the PSU (550W + cheap) and the case - I'm torn between the CM Storm Scout and a NZXT Guardian 921, I'd prefer a blue case and the temperature readouts are handy but I'm unsure of it's coolng credentials - it's well-reviewed but the Scout is widely regarded as a brilliant cooling box.On to the system then:
CPU: Core i5-750
Total: £731
Cheers,
Cyrl
