Credit cards finally paid off and I can afford my first self build.
I need the machine for High Definition video editing and Photoshop work.
My current 5 year old machine (Athlon FX-53 2.4GHz processor, 2GB RAM, and a Radeon X800XT GPU) struggles to keep up.
Hope to see improvement with the spec below:
CPU: Core i7 920 retail
Cooling: Akasa Nero AK-967
Motherboard: Gigabyte GA-EX58-UD5 or UD3
RAM: OCZ Gold 6GB DDR3 PC3-12800C8 1600Mhz
GPU: no clue - advice appreciated. Must drive dual monitors for video / photoshop work (one monitor will be full HD). Unlikely to game much but I may have the odd session (like the look of some of the new games e.g. COD MW2).
SSD: Kingston 40GB SSD (to hold OS and applications such as Photoshop & Sony Vegas only).
HDD 2 & 3: 2 x WD VelociRaptor 150GB 10,000RPM SATA-II 16MB Cache - OEM
DVD Drive: Pioneer DVR-S18L 22x DVD±RW SATA Dual Layer Labelflash ReWriter - Black (Retail)
PSU: Be Quiet! Dark Power Pro 550W ATX2.2 Modular SLi Compliant Power Supply
OS: Windows 7 Home premium (already bought on the cheap advance purchase scheme)
Case: no clue - prefer something sedate (no flashing lights or windows) but easy to work with for a first timer. Also, preferably should have filters on all air intakes. Ideally less than £ 100 - suggestions welcome.
Questions:
1) MOBO - UD5 or UD3? Fifty quid difference and I don't understand enough to judge if the extra spend is worth it. Only difference I could see is the supported RAM (24GB v 16GB) and I think my OS (Windows 7 Home Premium) is limited to 16GB anyway.
2) PSU - I presume 550W leaves me enough headroom should I wish to install another few hard drives or should I got to 650W?
All advice genuinely appreciated on any aspect of the build.
Cheers
BigLad.
Questions:
Cheers
BigLad.
Antec 300/900 range cases are the best bang for buck in my eyes. If your not gaming geting a proper workstation graphics card might be useful if your into HD editing (FireGL - I think that's what the AMD one is called or a Quatro by Nvidia). 550W should be fine.
