So i was looking to build a good gaming pc for under £500.. but after looking into it more i found i would need to spend more!
By the way i dont know that much about all these components and need to know if all the components i have are compatable and OK.
i5-2500k
GTX 560
corsair 8gb ram
ASUS P8Z77-V LX NEW Z77 Chipset
Samsung optical drive
Powercool 650W Modular PSU 80+ Dual 12V V2.2 High Efficiency
Zalman Z11
Gigabyte M6800 Optical Gaming Mouse
Emprex 5105GU Gaming Keyboard
Also near forgot i also need a Hard Drive,, can yous please recommend a cheap 1/2tb HDD!!
Also please tell me if there are any cheaper parts i should buy instead.. or anything i should spend more on to make it better! Thanks!
i5-2500k
GTX 560
corsair 8gb ram
Zalman Z11
Games are definately breaking the 1GB barrier now. You can certainly get by on a 1GB GPU, I have a 460 and it still holds up well.
