Self Install a Sky+ Box Possible
10 May 2004
East Yorkshire, UK
Hi
Managed to get hands on a Sky+ 160 box, is it possible to sle finstall? If yes are theyre any tutorials that you know of?
Thanks
Mate its really easy!
Are you upgrading from standard Sky?
If so its unplug all the leads out of standard box and plug into new Sky+ box.
Then call Sky to Pair your Card with the box. If you do it this way you will only
havea single tuner PVR so can only record what you are watching etc.
You will then need a quad LnB and another run of Co-ax to get your second tuner and real Sky+ features. TThis can be bought for £30 online ;)
Check out my thread, ive just done the same on thursday ;)
Andy
