Selling PC and want to wipe the hard disk. Best way?
29 Mar 2004
Cambs, UK
Hi all,
I'm going to be selling my HP Microserver shortly. It currently has the 160 GB hard disk that it came with.
I installed Ubuntu onto the hard drive and copied over my files to it. I've now copied off all my files and want to wipe the hard drive so that it doesn't have any of my files/stuff on it when I sell it.
How should I go about doing this? How does everyone here go about doing it when selling PC's/Hard drives?
Many thanks in advance.
Edward
I normally pop the drive out and put it in my main computer, then fill it with data from /dev/frandom (frandom is like urandom, only faster) a couple of times, to make me feel better. :p
Boot ubuntu live and run
sudo shred dev/sda -f -v -z –iterations==1
Change the HD address to suit and the iterations to the amount of passes you want to have. 1 should be more than enough unless your hiding from the police ;)
To cover against methods available to hackers at no expense, simply write zeros all over the drive.
To cover against extremely expensive methods use multiple shred passes when hot, normal and cold. After this, it's gone, srsly.
For SSDs it can depend on the firmware, write zeros to the device then leave it on overnight, or write zeros to it really fast 3 times back to back.
I use an Acronis tool that comes with their Disk Director software.
Did two passes each for two 1TB drives I sold recently.
TOOK ABOUT 12 HOURS :eek:
