Selling Up? Revised
17 Apr 2009
East Northants
Howdy all. New thread that follows the rules :cool:
Right, i think that it is time for an upgrade, but, being to impatient, i decided to buy an XPS 420 in october last year instead of building one. It was on a special so not too bad.
But, as everyone knows, the upgradability of Dells is pretty poor so it looks like a will be selling the XPS and building my own.
Just wanted to know what you think of the current spec:
its a Dell Motherboard (all branding is removed and replaced with Dell 0PT406)
Q6600 @ 2.4GHz
4GB Kingston HyperX PC6400 (2x2GB)
Nvidia GeForce 9800GT 1GB
LG Super Multi-Blue Blu-ray and HD-DVD ROM Drive
Bog standard DVD +- RW drive
Prosound 7.1 sound card
Dell 375watt PSU
Enermax Cluster 120mm fan
Enermax Everest 80mm fan
Built in Multimedia Card reader
Edit: 500GB Seagate Barracuda HDD (Keeping obviously)
Dont think i have missed anything.
Or should i take out the 9800gt, blu ray drive, RAM, fans and HDD. and put in standard parts in their place and sell it as a bog standard XPS and put the 9800gt bluray drive etc in my new build.
Im stuck at a crossroad... what to do?
p.s. Would have the money made from selling the above + £300 - £400 to spend.
EDIT: Got rid of the price check part. Sorry, you're right, i cant see that bit of the forum
The Motherboard is a BTX one and the BIOS is locked so you cannot tweak the voltages for the CPU, RAM, nothing :(
I will upgrade the PSU if i'm convinced to keep this system, but i am not sure if an ATX PSU will fit into my BTX case as i have had contradicting answers.
Thanks in advance and again sorry about the previous thread.
Cheers
Jack
It's a shame that BIOS is locked as you'd get 3.2GHz easily.. I would grab yourself a cheap X48 and a invest in a decent graphics card, like the HD4890.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-119-GI&groupid=701&catid=5&subcat=1050
http://www.overclockers.co.uk/showproduct.php?prodid=GX-126-XF
and a decent case to go with it :
http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-AN&groupid=701&catid=7&subcat=
Worth while and fruit full upgrade that for £285 (incl VAT)
The down side is you'll not get much if anything for your outgoing mobo .
Hmm.. ic in that case it seems that upgrading in this case would be a bit of a prob eh :/
( http://www.product-reviews.net/wp-content/userimages/2007/09/dell-xps-420-2.jpg )
u def need:
new mobo (for overclocks) Gigabyte GA-X48-DS5
http://www.overclockers.co.uk/showproduct.php?prodid=MB-119-GI&groupid=701&catid=5&subcat=1050 £99.99
new case (to take new mobo) --- depends on ur preference here... but for ex this is one of my personal favourites :) Hiper Anubis
http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-HP&groupid=701&catid=7&subcat=1170 £64.99
New PSU (375W is def not enough) --- Seasonic Silverpower 500W
http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-SS&groupid=701&catid=123&subcat=1099 £57.99
Also a new VGA would help greatly --- XFX ATI Radeon HD 4890 XT
http://www.overclockers.co.uk/showproduct.php?prodid=GX-126-XF&groupid=701&catid=56&subcat=1403 £140.99
Total 363.93 :) - whatever you can get for your old case+psu+ mobo+vga which would probabbly cut your costs by half :)
