Okay so I've had a quite a few random freezes video goes first then audio. Theres no correlation as to when it'll happen. I've stressed my GPU and CPU to their maximum both OC'ed and stock and no freezes occur. (currently running stock yet they still persist). The freezes only seem to happen within games as far as I can tell.
I can go for hours without an incident or maybe 10-15 minutes. Theres no BSOD and nothing significant is showing up in my event viewer. I've swapped out my motherboard which alleviated the issue for a small time.
I'm running watercooling with:
CPU: 2600k - stock
GPU: Gigabyte Windforce 3X GTX 670 - stock
RAM: 8GB of Corsair LP vengeance - stock timings/voltages
Motherboard: Asus P8Z68-V Pro (originally was a Asrock Z77 Extreme6)
PSU: Corsair AX750 gold
My system doesn't seem to overheat and the issue persists through stock settings. I've ruled out the motherboard as a culprit (via changing mobo) and I've ran memtest on my RAM. This leaves either the CPU or the GPU messing up. I'm not sure on any other steps to take to completely rule out either the CPU or GPU.
Cheers for any help.
CPU: 2600k - stock
