25 Apr 2015 at 07:59 #1 Deluxe1 Deluxe1 Soldato Joined 26 May 2007 Posts 6,299 Can someone recommend me a good set? Thanks.
25 Apr 2015 at 08:09 #2 eXist eXist Associate Joined 26 Jan 2009 Posts 1,114 conti speed cross or any other cyclocross tyre you like the look of
26 Apr 2015 at 17:02 #3 mattyfez mattyfez Soldato Joined 12 Apr 2007 Posts 12,250 http://www.chainreactioncycles.com/schwalbe-furious-fred-evolution-29er-mtb-tyre/rp-prod52617
26 Apr 2015 at 18:00 #4 touch touch Soldato Joined 28 Oct 2006 Posts 12,456 Location Sufferlandria mattyfez said: http://www.chainreactioncycles.com/schwalbe-furious-fred-evolution-29er-mtb-tyre/rp-prod52617 Click to expand... I think the Thunder Burts are supposed to be a better choice than Furious Freds? Supposedly more grip and less rolling resistance.
26 Apr 2015 at 18:29 #5 Deluxe1 Deluxe1 Soldato OP Joined 26 May 2007 Posts 6,299 These ones? http://www.chainreactioncycles.com/schwalbe-thunder-burt-evo-mtb-tyre-snakeskin/rp-prod118259#
26 Apr 2015 at 19:39 #6 touch touch Soldato Joined 28 Oct 2006 Posts 12,456 Location Sufferlandria Deluxe1 said: These ones? http://www.chainreactioncycles.com/schwalbe-thunder-burt-evo-mtb-tyre-snakeskin/rp-prod118259# Click to expand... Yep. I would choose Thunder Burts over Furious Freds but they still might not be the best choice for you. If you want semi-slicks to use your MTB on the road, go with exist's suggestion of narrow cyclocross tyres. If you just want MTB tyres which roll better on hardpack gravel/forrest tracks/dirt roads/etc, then I would go for the Thunder Burts.
