Hi chaps, currently putting together a very very cheap pc for a friend and couldn’t help but find out what these new low power 65nm Semprons overclock like before I put it back to stock and pass it over to the new owner.
Well the chip is a Sempron LE-1620 64bit with 2.4g stock clock and cost just 25 quid for a retail box, here is what I got out of this little beasty with just the lowly 1.25v stock vcore and oem cooler!
Probably not prime stable one bit, but still 3.2g is pretty impressive for a Sempron imo
Unfortunately this NF405 based Abit motherboard I used for the cheap build is real limited when it comes to overclocking. All you can change is FSB and HTT multi, can’t change cpu multi or ram dividers and most annoying of all you can’t change the cpu vcore!!
Better ram would bring the pi time down a tad also I recon.
Would love to know what it could do with a good cooler and loads more voltage!
