Sending an IP address (Not static)...
18 Oct 2002
Liverpool, England
Is there a free way of finding out the ip address of a broadband router which does not have an static ip address?
Is there a good IP mailing program that is free or is worth he money? (I have heard of 'IP Mailer 2004')
Or is there another way?
you mean duynamic dns? check out no-ip or dyndns
You simply run a client on the pc you want to know the ip for and type in a domain name (which never changes) and it will point to the ip and will change the record if needed. You can also get a router to do this for you if it supports it.
Sorry, my question was not very clear. I have now edited the first post. :o
Its the routers internet IP address I am after...
Look in the routers web interface.
What is the make/model so maybe someone can point you in the right direction?
Thanks for the replies... I will have a look at your suggestions :)
Stellios... I need to find out the IP when I am not in the house, but thanks anyway :)
My router is a Netgear DG834G.
