sending songs to ipod doesnt work .
Permabanned
22 Mar 2008
Redditch
got a Ipod classic(movies n pictures)all the folders are empty atm because i cant find the songs on the ipod.
Ive created a Music folder on my pc in IPOD [E],i look at the ipod and it says its sending but when i check the ipod,there is nothing on it.
Did you consider reading the instructions that came with your iPod, which must be all of about 20 words?
It is not so stupid if you are used to hard drive drag and drop players! Now that they don't come with a disk with iTunes it might be even considered counter-intuitive!
iTunes wil administer you collection and sync it with your iPod. There are very few workable alternatives.
