Sennheiser HD650 cable replacement.
5 Jan 2005
Cyprus
Started noticing that the audio was getting distorted when l moved my head. The audio was becoming distorted when moving the cable so it seems like there is a break within the cable. I own these headphones for almost 10 years so it's time for a new cable. I searched for the original cable on Sennheiser's website and while it only costs €10 it only ships for Germany and Austria with no local dealers offering the original wire. Do you guys use or recommend any aftermarket solutions?
Thomann carry it...
I was going to go for it but after seeing the €30 delivery charge l changed my mind. Apparently, there is a guy who makes custom cables in the U.K. You can choose length and connector type. Pretty much the same costing but hoping the custom cable job will be more durable than the standard wire.
For my HD600s I bought a couple of mid-priced ones off Amazon so I could DIY different connections - personally don't notice any sound quality difference to the original cable but other people might have a different experience.
