Hi Guys
thought I would give you all a heads up about the new communicator for XBOX360 from Sennheiser.
with stock due in soon, this is a bargain price for a high quality communicator for your 360
Sennheiser X2 Xbox 360 Headset @ £19.99 inc VAT
This is the only Communicator Headset We will sell simply because its the only one worth having!
Upgrade your Xbox 360 with the X 2 – and hear to win with Sennheiser sound. The robust, comfortable build of headset and in-line volume control give you lots of great game time on Xbox LIVE, at an affordable price. And because clear talk with fellow players is a must for true gaming action, the X 2 features quality noise canceling microphone.
* Sennheiser sound – hear your teammate or opponent on Xbox LIVE in clear quality without having to strain your ears;
* Durability at great value – robust build designed to last;
* Noise canceling clarity – the microphone is highly sensitive, so you can talk to your teammate or opponent without needing
to shout;
* Light and comfortable – play for hours on end and forget that you’re even wearing a headset;
* Easy controls – easy-to-use volume control and mute switch built into the cable for quick access;
* Keep one ear free – the single-sided design allows you to hear the game’s audio on the TV while chatting via Xbox LIVE;
* 2 Years Manufacturers Warranty;
* Cable length: 1.1m / 3.6ft;
* Connector sockets: Mic & Audio 2.5mm;
* Weight: 54g;
* Headphones;
* Frequency response: 42-17,000 Hz;
* Impedance: 32?;
* Sound pressure level: 95dB;
* Microphone;
* Frequency response: 90 – 15,000Hz;
* Pick-up pattern: Uni-directional;
* Impedance: 2k?;
* Sensitivity: -40dBV/PA;
* Dimension of product packaging (W x H x D): 212 x 244 x 64.5 mm;
* Dimension of inner master carton (W x H x D): N/A x N/A x N/A;
* Dimension of outer master carton (W x H x D): 480 x 382 x 520 mm;
* Warranty: 2 Years Manufacturers Warranty;
Only £19.99 inc VAT.
ORDER NOW
to shout;
* Weight: 54g;
* Headphones;
* Impedance: 32?;
* Microphone;
* Impedance: 2k?;
ORDER NOW
