Senns GSP 300, Hyper X cloud 2 or Sony Gold Wireless (2018 model) for PS4
7 Oct 2010
I'm not sure which headset to go for. I play on PS4 but I also like watching films through headphones. I don't care if they are wireless or wired, and I only have a budget of £80. I've narrowed it down to the headsets I've specified in the title. I do often talk to friends online so I need a headset with a microphone.
NOTE: The Hyper X Cloud 2 had a firmware release which allows the PS4 to support the USB soundcard, so that will need to be taken into consideration.
I can't decide out of the three which will be a good option, so any help will be appreciated
I'd go for the HyperX Cloud II, especially if the USB dongle now works with PS4. Easily the best headset available for £60-£70
No point bothering with wireless headset unless you can spend a chunk of money. Even then they are overpriced. Wireless headsets have extra electronics over a standard wired headset, meaning either they cost more to accommodate that, or everything used is that much cheaper. If there are wireless headsets for around £70, you'd be scraping the bottom of the barrel.
