- 19 Oct 2002
Hear me out. I'm looking for a 'do-everything' rig. High end gaming, video editing, good fast storage.
I want it to be very quiet when doing simple tasks as I record video/audio in the same room. But when I play a 4k game, I don't mind it getting a bit noisier.
I already have Keyboard, mouse and monitors. I'll also use my existing 1060 gfx card from my old PC until the new 5900xt comes out later this year.
Spec:
AMD Ryzen 9 3900X - £449.99
https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3b5-am.html
ROG STRIX X570-E GAMING (AMD AM4) DDR4 X570 CHIPSET ATX MOTHERBOARD (£314.99)
https://www.overclockers.co.uk/asus...4-x570-chipset-atx-motherboard-mb-6dv-as.html
Corsair VENGEANCE LPX 64GB (32*2) DDR4 3600Mhz (£359.99)
https://www.overclockers.co.uk/cors...3600mhz-dual-channel-kit-black-my-4cf-cs.html
2* Samsung 970 EVO Plus 2 TB PCIe NVMe M.2 (£449.99 *2)
https://www.overclockers.co.uk/sams...-3.0-x4-nvme-solid-state-drive-hd-23z-sa.html
Corsair HYDRO SERIES ICUE H150I PRO XT RGB PERFORMANCE LIQUID COOLER - 360MM (£154.99)
https://www.overclockers.co.uk/cors...uid-cooler-360mm-cw-9060045-ww-hs-03z-cs.html
BeQuiet SILENT BASE 600 MIDI TOWER CASE - BLACK (£104.99)
https://www.overclockers.co.uk/be-quiet-silent-base-600-midi-tower-case-black-ca-105-bq.html
Corsair RM SERIES RM850 850W '80 PLUS GOLD' MODULAR POWER SUPPLY (CP-9020196-UK)
https://www.overclockers.co.uk/cors...lar-power-supply-cp-9020196-uk-ca-24t-cs.html
3* Noctura NF-A14 PWM FAN - 140MM (£18.95)
https://www.overclockers.co.uk/noctua-nf-a14-pwm-fan-140mm-fg-021-nc.html
4* Noctura NF-A12X25 PWM FAN - 120MM (£29.99)
https://www.overclockers.co.uk/noctua-nf-a12x25-pwm-fan-120mm-fg-06r-nc.html
Total order value
£2,594.93
Key questions:
1) Anything not fit together?
2) Does the Liquid cooler fit in the case?
3) I plan to replace the corsair hydro fans with the noctura ones on the cooler. Worth it?
4) Is 3600MHz ram better than 3200MHz?
Spec:
Total order value
£2,594.93
Key questions:
SAVE 20%
£200
(incl. VAT)
£160
(incl. VAT)
