Guys,
I am embarking on my first PC build since loosing touch with self build in the days of Cartridge CPUs.
I was planning to buy a MacPro, but decided I can get more for my money from a PC. I already have a 27" Apple monitor on order so need a GPU with a "Mini DisplayPort" (not the same as standard display port) connector on it.
Below is what I have picked out.
Priorities for me are
Needs to be quiet.
Fast IO. I hate waiting for copying etc.
Will be used as a Media server to stream HD content.
MS Web Dev (using visual studio 2010)
Mild Photo and Video editing from HD Vid Cam and DSLR
Gaming -(but in reality probably only for a short period of time if a killer game comes out. Not a hard core gamer at all)
You may think that this machine is overkill if I dont play games often, but I dont buy/upgrade my machines very often. My current PC is 5 years old. I buy high spec and make it last.
Also, I am not going to OC it to within an nM (see what i did there
) of its life, but happy to OC it a little to make it work for its money
Krypton Intel Core i7 970 3.20GHz @ 4.00GHz Overclocked Bundle - £1004.63
Corsair Hydro H70 High-Performance CPU WaterCooler - £83.99
HIS ATI Radeon HD 5870 2048MB "Eyefinity 6 Edition" GDDR5 PCI-Express - £352.49
Intel X25-M Mainstream 80GB 2.5" SATA-II Solid State x 2 in RAID -£315.98
Coolermaster RC-1000 Cosmos Silent Full Tower Case - Black - £156.99
Corsair TX 750W ATX SLI Compliant Power Supply - £89.99
LG BH10LS30 10x BluRay-RW / 16 x DVD±RW Drive - Black (OEM) - £89.99
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM - £51.99
LG GH24NS50 24x DVD±RW SATA ReWriter (Black) - Retail -£17.99
The Krypton bundle includes
- CPU: Intel Core i7 970 3.20GHz @ 4.00GHz
- Motherboard: Asus P6X58D-E (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
This lot comes in at £2164 which is slightly over my initial budget of £2k
What would you change in this setup and why?
Within the same budget, would it be possible to increase ram, and SSD storage space? maybe by reducing the cost of the GPU? Are there any cheaper GPUs with mini display port connectors?
What is the difference between the 970 and 980 ?
Thanks for your help
Needs to be quiet.
