Sensor Cleaning - what do you use ?
19 Oct 2002
Pembrokeshire
Just wondering what you guys use to clean the senors in your DSLR's that have dust on them. I noticed I had some dust the other night after shooting some landscapes at F22.
I bought some sensor swabs and liquid for cleaning but it didn't go too well.. first attempt made things worse, following 3 attempts just seemed to move the marks around, finally on the 4 or 5th attempt I got it OK but to be honest would prefer not to do it this way again. Surely there's something nice and easy ? :)
Jase
Same, but there's now a (relatively!) huge hairball clinging to the sensor and refusing to let go. I've heard Sensor Swabs with Eclipse Fluid are the best combo to go about removing it?
Think I'll keep an a watch of the dust and clean more often now.. hopefully won't have to do it when I get the 40D but we'll see...
It was the Sensor Swabs with Eclipse 2 fluid I used. Did a good job in the end but I wasn't that good !
Jase
For small, easily movable dust, blower.
For larger, persistant stuff I've got a product called Dust-Aid, which is basically very low strength adhesive pads to lift the dust off the sensor. It's pretty effective and nowhere near as fiddly as swabs and such.
