- 10 May 2007
Hi all,
Can anyone provide any further advice on the issues we have been having below?
Daewoo Matiz went to the garage reporting P0133 (oxygen sensor circuit slow response)
The oxygen sensor was replaced with an OEM part but the issue remained although with the code P0131 (02 sensor low voltage) It was then replaced with an original Daewoo part which we had hoped resolved the issue as it never reappeared for a few weeks. Unfortunately though the light has come back on again reporting the original P0133 error.
As well as the above, the garage has cleaned every other sensor going on the car including MAF as well as rerouting the sensor wiring as they read that there could be a fault when going straight from A to B.
Does anyone have any ideas? Could the new sensor be faulty? The work is being done at a large garage so they are not cowboys but I think everyone now is starting to run out of ideas..
Any input would be appreciated!
Matt
Matt
