Serial Communication - You can help!
THT
THT
10 Mar 2004
Im trying to emulate an existing program which writes to the serial port.
I have the output of what the program does (which works) and what program does (which doesnt work)
I can only see one difference between them and fc.exe doesnt help as the timings are different.
So heres your task - what differences are there between the following 2 blacks of code (ignore the second column)
Working:
Code:
0	0.00005978	LED.exe	IRP_MJ_CREATE	Serial0	SUCCESS	Options: Open
1	0.00000307	LED.exe	IOCTL_SERIAL_GET_TIMEOUTS	Serial0	SUCCESS
2	0.00000168	LED.exe	IOCTL_SERIAL_SET_TIMEOUTS	Serial0	SUCCESS	RI:0 RM:10 RC:1000 WM:1 WC:1000
3	0.00000168	LED.exe	IOCTL_SERIAL_GET_BAUD_RATE	Serial0	SUCCESS
4	0.00000140	LED.exe	IOCTL_SERIAL_GET_LINE_CONTROL	Serial0	SUCCESS
5	0.00000168	LED.exe	IOCTL_SERIAL_GET_CHARS	Serial0	SUCCESS
6	0.00000168	LED.exe	IOCTL_SERIAL_GET_HANDFLOW	Serial0	SUCCESS
7	0.00000140	LED.exe	IOCTL_SERIAL_GET_BAUD_RATE	Serial0	SUCCESS
8	0.00000168	LED.exe	IOCTL_SERIAL_GET_LINE_CONTROL	Serial0	SUCCESS
9	0.00000140	LED.exe	IOCTL_SERIAL_GET_CHARS	Serial0	SUCCESS
10	0.00000168	LED.exe	IOCTL_SERIAL_GET_HANDFLOW	Serial0	SUCCESS
11	0.00001034	LED.exe	IOCTL_SERIAL_SET_BAUD_RATE	Serial0	SUCCESS	Rate: 1200
12	0.00000447	LED.exe	IOCTL_SERIAL_CLR_RTS	Serial0	SUCCESS
13	0.00000447	LED.exe	IOCTL_SERIAL_CLR_DTR	Serial0	SUCCESS
14	0.00000335	LED.exe	IOCTL_SERIAL_SET_LINE_CONTROL	Serial0	SUCCESS	StopBits: 1 Parity: NONE WordLength: 8
15	0.00000196	LED.exe	IOCTL_SERIAL_SET_CHAR	Serial0	SUCCESS	EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
16	0.00000335	LED.exe	IOCTL_SERIAL_SET_HANDFLOW	Serial0	SUCCESS	Shake:0 Replace:0 XonLimit:2048 XoffLimit:512
17	0.00000168	LED.exe	IOCTL_SERIAL_SET_QUEUE_SIZE	Serial0	SUCCESS	InSize: 4096 OutSize: 4096
18	0.00000279	LED.exe	IOCTL_SERIAL_SET_WAIT_MASK	Serial0	SUCCESS	Mask: RXCHAR
19	0.00000223	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
20	0.00000279	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
21	0.00002235	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
22	0.00000223	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
23	0.00845247	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
24	0.08334914	LED.exe	IOCTL_SERIAL_WAIT_ON_MASK	Serial0	CANCELLED
25	0.00000503	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
26	0.00822786	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: Y
27	0.00000223	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
28	0.00828709	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
29	0.00000279	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
30	0.00802197	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
31	0.00000223	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
32	0.00828792	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
33	0.00000447	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
34	0.00824686	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
35	0.00000279	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
36	0.00808790	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
37	0.00000279	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
38	0.00826893	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
39	0.00000251	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
40	0.00828848	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: G
41	0.00000335	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
42	0.00776439	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
43	0.00000810	LED.exe	IRP_MJ_CLEANUP	Serial0	SUCCESS
44	0.10976619	LED.exe	IRP_MJ_CLOSE	Serial0	SUCCESS
Not Working:
Code:
0	0.00005503	LED.exe	IRP_MJ_CREATE	Serial0	SUCCESS	Options: Open
1	0.00000335	LED.exe	IOCTL_SERIAL_GET_TIMEOUTS	Serial0	SUCCESS
4	0.00000168	LED.exe	IOCTL_SERIAL_GET_LINE_CONTROL	Serial0	SUCCESS
5	0.00000140	LED.exe	IOCTL_SERIAL_GET_CHARS	Serial0	SUCCESS
8	0.00000140	LED.exe	IOCTL_SERIAL_GET_LINE_CONTROL	Serial0	SUCCESS
10	0.00000140	LED.exe	IOCTL_SERIAL_GET_HANDFLOW	Serial0	SUCCESS
11	0.00000950	LED.exe	IOCTL_SERIAL_SET_BAUD_RATE	Serial0	SUCCESS	Rate: 1200
12	0.00000475	LED.exe	IOCTL_SERIAL_CLR_RTS	Serial0	SUCCESS
13	0.00000475	LED.exe	IOCTL_SERIAL_CLR_DTR	Serial0	SUCCESS
15	0.00000168	LED.exe	IOCTL_SERIAL_SET_CHAR	Serial0	SUCCESS	EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
16	0.00000307	LED.exe	IOCTL_SERIAL_SET_HANDFLOW	Serial0	SUCCESS	Shake:0 Replace:0 XonLimit:2048 XoffLimit:512
20	0.00000168	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
21	0.00002179	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
22	0.00000196	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
23	0.00857120	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
24	0.00000559	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
25	0.00827005	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: Y
26	0.00000587	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
27	0.00826111	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
28	0.00000559	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
29	0.00825608	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
30	0.00000363	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
31	0.00828848	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
32	0.00000419	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
33	0.00828066	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
34	0.00000419	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
35	0.00828290	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
36	0.00000559	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
37	0.00826418	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
38	0.00000559	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
39	0.00826083	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: G
40	0.00000587	LED.exe	IOCTL_SERIAL_PURGE	Serial0	SUCCESS	Purge: TXABORT RXABORT TXCLEAR RXCLEAR
41	0.00826446	LED.exe	IRP_MJ_WRITE	Serial0	SUCCESS	Length 1: .
42	0.00000363	LED.exe	IRP_MJ_CLEANUP	Serial0	SUCCESS
43	0.11121721	LED.exe	IRP_MJ_CLOSE	Serial0	SUCCESS
Second one is missing,
If that matters :)
