Serial Number
Permabanned
23 Apr 2006
Earth
My mate had a PC built by someone in Uni and it turns out that the windows thast was put on was not a legal copy!! Unfortunately the guy that built the PC has now left the UNI. My mate has bought a legal version of XP but instead of re-formatting etc, is there a way he can put the serial number of the legal XP into his pc without formatting? They are both XP Pro.
He does not want to format. He has a lot of gb's of files on the pc. Thanks
there is a way of unregistering windows so that you can enter a new key and re-register, however unless the version installed is the exact same as the version your mate has bought, the new key will not be accepted.
the magical jelly bean key finder allows you to view your current key and also change it to a new one so its exactly what your mates after
