As title I have a Asus Rampage Formula I purchased on the 25/02/2010. It was running fine and I was wrongly checking my temps with CPUID Hardware monitor. I thought things were fine. I then OC my Q9550 from 2.83Ghz to 3.9Ghz, Im also running crossfire 5850's at 1.15v 900/1200.
Recently my pc just kept shutting down and I could not figure out why. I thought it was the GPU's overheating . I then installed good old Everest and found I think the problem. With my Oc in place my Northbridge temps hit 78-86 degrees and SB 55 degrees. Eventhough the pc protection temps are 90 at 86 it goes off. This is too hot I think. at one point it was 184 degrees F.
Should I RMA the board to seller, I think the board for its cost should be pushable. Even now with my OC right down to 3.4 and my NB voltage down Im showing 63 c at idle. Far too hot. Anyone agree.
