If I start from any city, outpost or other location the game just freezes up within 1-2 minutes!
Now after I've hit the PC's reset button, that's the only way to get out the game, and the PC's rebooted my ADSL modems icon, those two up/down arrows, shows up as red in the system tray and say's there's no signal!
However, if I pull the USB socket out and plug it straight back in the modem works just fine! Anyone have any ideas what could be causing this?
One problem is that seen as GW is being played when this occurs, I can't see exactly what's going on with the connection lights. Although when the game freezes, all three lights on the modem (Power, DSL and Data) stay lit.
This only started last-night, up until then everything was working fine and I was actually playing Guild Wars for an hour or so before. Nothing's been installed, updated or un-installed at all.
By the way, surfing the interweb is just fine, it doesn't drop connection at all.
Anyone have a clue? Thanks
). Remove the card and attempt to push the fan around with you finger this may prove a little difficult if the fan has come off it's spindle...your card is probably still under warranty so just return it
