serious help needed with screw up!
14 Aug 2006
NoWhere
so i've screwed up, clicked on some crap i werent supposed to, thought it was adobe flash player hd, run the application and it rebooted pc, now i constantly have a message coming up from launch bar saying stuff like "your pc is infected with spyware click here to remove" etc
also a window popping up every now and then saying windows security alert, trojan software, clikck here to download spyware removal software
any help much appreciated
thanks
S
any recommendations for a free scanner/fixer!?
im sure ive done this before a few yrs ago and a scanner didnt even pick it up?
DONT "click here to remove"
sounds like some scam where it looks like your pc is infected and they charge you money to remove it.... (
see if you can work out the name of the virus/trojan and then look it up on google for removal instructions as each can be slightly different.
some anti virus programmes do not catch these as you have to approve the installation when it asks you, you probablly clicked yes
disable system restore
ccleaner
nod32 av trial (for a one time scan)
spybot s&d
o&o defrag trial (will work wonders)
ocuk forums*
*now featuring 'future quote'
just for reference, i first tried combofix and vundofix and they wouldnt even run, both installed, but wouldnt run, and task manager wouldnt work,
