ok... guys I really can do with some help..
been an nvidia fan all my life and i was veryyyy close on getting 2 7900GTs until.... i had a flashback to check on ATIs.. well I can now say that I am almost hooked to the idea of getting 2 1900XTs..
and here is the problem... SLi.. ok easy... but crossfire has me a bit... well messed up to be honest!!! :s
so the question....: will 2 x
Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-112-SP) work??
cause ok I heard... there is a Master/Slave configuration that you have to follow... but to be honest.. ocuk is the only vendor that actually have an ATi card refered to as MASTER.... none of the competitors have
so is there any easier way of spotting them..?
2nd question... : will a Slave card work by its self? or a standalone has to be a Master?
and 3rd and final question...:
what are your thought on Saphire motherboard?
personaly i love the white PCB and Ati mobo with Ati gfx.. well it kinda sounds nice
so guys can you help a bit..? well a lot?
tnx all
tnx all
