Hey guys, my first post. I recently decided to upgrade my old system and go into the unknown terratory of DDR3 and AM3.
My Specs :
1090T X6
Vengeance 1600MHz 8GB (2 x 4GB)
Asus m4a87TD EVO
This was working fine on stock so I slowly overclocked, I hit a wall at 4.2GHz with the ram using 9-9-9-24-41-1T timings at around 862MHz. All was fine until I started my computer the next morning. It kep Blue screening at the windows login page. Had trouble since
All of a sudden no config will pass more than 5 mins on Prime95 and im really stressed.
Here was the config in more detail
[email protected] 1.5v
mem @1680 1.55v
everything else was left to auto.
I have tried both sticks in all slots and used each at one time, reset bios etc etc. Now I am running the default config so cpu @3.2, mem with default timings and voltages.
I can't run Prime95 for 10 mins without it coming up with this "FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file." usually only on one core. Sometimes Prime95 will just close by its self and my allcpumeter in the top right goes a funny colour so I have to turn off.
Any advice will be MUCH appreciated.
Thank you
**edit - I flashed the bios to latest version, same issues
My Specs :
1090T X6
Asus m4a87TD EVO
mem @1680 1.55v
Thank you
- Keeps it all in check - every board suffers vdroop.
