Hello, well my pc was fine, however it then showed no output on the monitor, however the CSD said "Vertical frequency" ...
However my pc was switched on the whole time, the fans were spinning etc as normal. I switched it off manually holding the power on button, switched m pc back on and it said windows has recovered from a serious error....
This has happened 3 times now.
RIght, in the event viewer in administrative tools in control panel, it comes with the following error :
Error code 1000000a, parameter1 00000016, parameter2 00000002, parameter3 00000000, parameter4 804f8c38.
Event Id : 1003
Category : 102
System error
Event Id : 1003
Category : 102
System error
