Serious problems with Abit AB9
8 Mar 2007
Incase you have problems with ABit AB9
Hi,
I recently purchased the ABit AB9 Pro motherboard as part of the overclockers bundle http://www.overclockers.co.uk/showproduct.php?prodid=BU-052-OK&groupid=701&catid=339&subcat=
The only problem is, the bundle that they have "carefully selected" does not work, it took 3 hours and numerous BIOS updates to get it to actually boot with the RAM.
In the end the fix that sorted the problem was to manually set the RAM voltage to 1.9V rather than the 2.1V the motherboard was selecting.
