serious sam2 i`m seriously stuck
24 Apr 2003
greater manchester
i`m stuck on the chanolin level where there is a temple with loads of guys and rhinos coming out of it,ive got the canon and found the dragon which you can turn on to breath fire(for all the use it is!) but no matter how many i kill they just keep respawning! i guess i must be missing something but i just can`t suss it out. can someone please help me out before i go barmy? :mad:
you can get smash them for ammo/power ups but is there something you have to do to stop them respawning? i found a spot where they quite get at me but they all start piling up till untill there is loads of em, then you blow the whole lot up and they just start spawning again! have you played this game right through?
Yes I've completed it. IIRC at the start of that stage there is a load of those big balls rolling at you, what I do there is use rockets from a distance and then switch to shotgun when they get in close. This saves up your minigun/cannonball ammo for when you need it later, and you can replenish your rox from the alcoves behind you. Also if there are any powerups like serious damage, don't take it in the first part of the level, save it for the bit you are having trouble with.
From what I remember they aren't infinitely respawning and if you persevere you should be able to kill them all. There's that big long pathway near the start of the level with the statues at the sides, what I did was spam loads of rockets when the enemies first start coming, and then back away down the pathway using cannonballs when they are approaching you. Next best weapon is of course the minigun which can really cut through these guys.
