So heres the situation, I just recieved the Steelsound 5Hv2 USB Headset.
I install it all and it works great.
Heres the problem, the very second I plug my Xbox 360 contorller for Windows in, the sound going to the headphones is something atrocious, its all sounds metallic in sound.
If i restart the computer with both plugged in, same issue, if I have the 360 controller in first then plug the headset in, same thing.
Its not just with the steelsound either, it was doing it with my old headset, a logitech USB 120 (which i thought was broke, so i bought the steelsound).
You wouldnt think it would ya, but that damn 360 controller screws everything up.
the only common link I see is the 360 controller is interfering with USB sound ??
If anyone else has, or had, this problem, PLEASE HELP.
