Seriously annoying boot/driver issue? :(
8 Oct 2009
United Kingdom
Was wondering if any of you know what my problem is!
If this cannot be resolved, i'll format my machine.
It all started a few hours ago upon trying to enable Intel's virtual machine software thing in my BIOS. This was to get Windows 8 Hyper-V function up and running.
Upon enabling Intel® Virtualization Technology, saving the bios and restarting my pc, my system loaded through to desktop, and 1 minute later froze, totally froze, not a black screen, or a blue one, just froze on desktop.
I restarted my machine, same freeze again after 2-3 minutes. So i disabled Intel® Virtualization Technology, and rebooted, same problem again, i did a system restore to earlier in the evening before any of this started - SAME problem again. Still freezing after a few minutes.
I go to my event viewer and this keeps popping up but i cannot make sense of it! - I'm guessing it's my sound driver? - yet I've never had this issue before.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
<EventID>219</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>212</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2013-01-20T23:56:43.998605100Z" />
<EventRecordID>60151</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="120" />
<Channel>System</Channel>
<Computer>Oli-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="DriverNameLength">46</Data>
<Data Name="DriverName">WpdBusEnumRoot\UMB\2&37c186b&0&STORAGE#VOLUME#</Data>
<Data Name="Status">3221226341</Data>
<Data Name="FailureNameLength">14</Data>
<Data Name="FailureName">\Driver\WudfRd</Data>
<Data Name="Version">0</Data>
</EventData>
</Event>
Im writing this from the machine itself. Seems to be stable for a random amount of time before freezing. System has been fine 6 months prior to tonights problem. Sorry for the long post, cheers for reading if you did!
ignore me if a stoopid comment :)
have you turned anything off in bios like fans and it's over heating, if you think it's the driver have you uninstalled?
Yeah fans are running , temps are normal, event logs just keep mentioning that error.
Update : I've re-installed Realtek audio drivers for win 8 (2.69), still same issue.
Im running a Gigabyte GA-Z77X-UD5H Motherboard, sometimes when restarting, the BIOS loadup becomes stuck/jammed. I get the following debug codes displayed on the motherboard at random times when restarting my machine:
62 - Installation of the PCH run time services
A2 - Detect and install all currently connected IDE devices
I have no idea whats going on, who am i.
The error is basically saying your storage system is failing to respond. This could be HD/CD ROM/USB stick/Card reader.
Try resetting your bios to optimized defaults and starting from there. If this is not a clean install then it's probably time to consider that too.
Cheers Yashiro, will give those a go tomorrow and see if i can come up with a stable system.
Also going to try using the windows 8 'Reset your pc' function as well.
Really strange how all these errors have been caused just by trying to enable the Intel® Virtualization Technology, my bios must just be touchy :P
