Server 2008 System State Backups - Solved
18 Oct 2002
Nordschleife
OMG why did MS remove ntbackup? :mad:
So we now have a 2008 DC and I need to backup the system state - Great I have found the command for that
PHP:
wbadmin start systemstatebackup -backuptarget:e: -quiet
But I only need 1 version of it so how the hell do I clean off the old backup files?
Tried:
PHP:
wbadmin delete systemstatebackup –deleteOldest
wbadmin delete systemstatebackup -backuptarget:e: –deleteOldest
Both fail? What am I doing wrong?
Yeah found that now and I think I must have type something in wrong to begind with - Just doing a couple of backups and will test the command again
PHP:
wbadmin delete systemstatebackup -backupTarget:e: -deleteOldest
The only difference i have noticed from the command you wrote and the example listed on the MS site is the colon after the drive letter.
Restoring System State
Again this isnt easy, probably as its just different way than we have all used.
PHP:
wbadmin get version -backupTarget:e:
PHP:
wbadmin start systemstatereovery -version:01/01/2009-17:00 -backupTarget:e:
