Server 2012 on USB drive?
15 Nov 2007
Sheffield, UK
I can't seem to find much info on this as all that comes up is making a bootable usb drive for the installer files and not much on actually installing it to a usb drive? Is this possible?
OP asks about installing 2012 to USB, specifically saying he doesn't want to install it from USB..... Gets 2 replies telling him how to install from USB.
I'm not sure it would be possible, or even sane to be honest. It's not designed to be an embedded type OS - it's one thing running something like ESXi from USB as you don't lose much if the USB stick dies and you don't need the capacity.
It begs the question......why?
I think the frequency of writes to the 'HDD' would wear out the flash in the USB stick pretty quickly too. I think your best bet might be to install to a HDD as normal and then clone the two partitions onto the USB stick.
Probably the only way to do it, use clonezilla or something. If it works at all it's still a bad idea!
Its not a production environment, just my home server. It's basically going to be treated as a hyper-v / esxi / xen server. So i thought it would be convenient to install each to a USB drive. On the long term i'd be using server 2012, but it would just be a glorified hyper-v server with anything substantial running in backed up VM's. The base 2012 install would only every do hyper-v processing and possibly file server duties. So reliability isn't an issue really since these can be re-setup quickly
