Server crashes - check Asetek liquid cooling working?
16 Apr 2020
Hi,
I hope this is the right forum.
My server is crashing and I am looking for advice.
I bought this in 2017 (see configuration at end) and it has worked reasonably well until now.
There was a power cut a few days ago and I think this may have caused the problem.
The machine boots. There is enough time to sign in and do a few minutes work and then it freezes. It then shuts down after half an hour.
I managed to get a look at the event logs and saw this likely problem:
Microsoft-Windows-WHEA-Logger Event ID 16 - A fatal hardware error has occurred. - Component: PCI Express Root Port - Error Source: Boot
I wondered whether the NVMe drives had some problem.
I managed to open the BIOS and just happened to notice the CPU temperature was 96.7 Centigrade (206 Fahrenheit). This looks to me like overheating.
I’ve opened up the box and wondered whether there might be a problem with the Asetek liquid cooling (https://www.overclockers.co.uk/ocuk...-liquid-cooling-upgrade-bundle-bu-098-tl.html). However, I am not sure how to check whether it is working – there are no visible moving parts.
Server Configuration
CP-61S-IN Intel Xeon E5-2650v4 2.20GHz 12-Core with Hyperthreading
MB-68G-AS Asus X99-WS/IPMI Intel X99 (Socket 2011) DDR4 Workstation Motherboard
HS-04A-AS Asetek 360mm 591LX (35-102-0000026)
HS-045-AS Asetek Premium Retention Kit Intel LGA2011 (35-150-0000015)
HD-207-SA Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV256HDGL-00000)
HD-193-SA Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU)
HD-070-IN Intel 750 Series 1.2TB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW012T4X1)
CA-030-SF Super Flower Leadex Platinum 1600W Fully Modular "80 Plus Platinum" Power Supply - Black
CA-118-BQ be quiet! Dark Base 900 Full Tower Gaming Case - Black
FG-063-NB System Build Fan - Noiseblocker BlackSilent Pro Fan PLPS - 120mm PWM [EXNO-001]
FG-063-NB System Build Fan - Noiseblocker BlackSilent Pro Fan PLPS -120mm PWM [EXNO-001]
GX-271-AS Asus HD 5450 SILENT 1024MB GDDR3 PCI-Express Low Profile Graphics Card
MY-463-CS Corsair Vengeance LPX 64GB (4x16GB) DDR4 PC4-19200C14 2400MHz Dual/Quad Channel Kit - Black (CMK64GX4M4A2400C14)
(Socket 2011-3) - Retail
