Got a bit of an issue
had a power cut, didnt know about it , air con had turned off.
servers are boiling hot as is the room.
what i want is a solution so that i can tell if the air con is of.
is there such a thing as a temp sensor that i can get to email me if the temp rises higher then xx degrees
