Server Storage Chassis
RSR
RSR
17 Aug 2006
Hey Chaps,
I've been looking for a Server Chassis that I am able to fit up to 16/24x 2.5 drives in for a self build, as I am looking at changing my current box for something that's a little bit more power efficient. Can anyone recommend any beard bones chassis? It also need to be somewhat quiet. :p
I've found a few on a large market place and also a few from Supermicro. The Supermicro ones look good but the 80mm 5600 rpm fans put me off a little.
The reasoning behind looking at the 2.5 form factor is the power savings which can bit had. In the current setup I am using 5 Seagate 7200.14 2TB (ST2000DM001) drives which leaves me plenty of space for storage and my virtualization lab. Looking at the power usage in watts. These drives typically idle @ 5.80w and under loads this would normally rise to 8+w Spec
I then started looking at other manufactures drives which seems to be about on par or work for a similar spec drive, which when you start adding drives it soon mounts up. Looking at the WD RED range, they seem to be the best fit for my requirements as their power requirements in 3.5 versions are half that of the current Seagate drives for similar levels of performance. Then I noticed that 2.5 (WD10JFCX) drives, these come in at 1.4w under load and 0.6w when idle. This means with my current HDD setup is using 50~w with 5 drives if I moved to the 2.5 drives id require 9 of them but the total watt usage would be reduced to 12.5~w which is a 37.5 watt saving. So this got me thinking about my whole storage solution and how I can optimise it, I can reduce the Xeon E3 - 1230 which is 80w TDP for a 1220L which is 20w TDP. As this is running ZFS a 1230 is a little bit over kill to be honest.
So looking at the HDD and CPU option I could potentially save around 100watts.
Posted in your other thread as you edited :p
This potential 100w will save you, what, £130 in a year if you are genuinely saving 100w 24/7?
100w is about 1.49 pence per hour of operation (depending upon the price you pay on electricity). Over 8765.81 hours (a year, according to google) that's 13061.0569 pence
That's if you are hammering this setup 24/7.
LOL. :p
Just thinking aloud really at the moment, its roughly around that round that. It also could bring some plus points with more spindles improving random access time etc...
Its never really idle to be honest, as I have a number of hypervisors connected. However, I don't hammer it 24/7.
I know the total at the moment for all 3 servers and a switch is 200 / 240watts which to be honest isn't really bad. Its still loads less than the fridge for example.
My first thought was that any chassis for 24+ 2.5" drives would be designed for a rack in a server / DC and thus not care about noise.
Logic Case do a 2U chassis (the SC-2332) for 32 2.5" drives - that has 4 x 80mm fans which you could possibly swap for quiet ones if you only have a few HDs.
That's one of the cases I have been looking at, again its the 80mm fans.
Looks like I need to do a little bit more research. :D
If size isn't an issue (stop sniggering at the back), why not just get a Norco clone (I can think of 2 UK retailers who do them). The drive sleds will take 2.5" drives and you could change out the fans for much quieter ones as you will have improved airflow?
