16 Dec 2006 at 23:32 #1 GeForce GeForce Soldato Joined 14 Feb 2006 Posts 4,644 Location Surrey, UK Basically, I have two computers, each with a Netgear WG111 Wireless USB 2.0 54Mbps Adapter. However, they are only connecting at 11Mbps. Why? And how do I get them to connect at the full 54Mbps? TIA, Jon
16 Dec 2006 at 23:35 #2 VeNT VeNT Soldato Joined 9 Jan 2003 Posts 21,158 Location Cornwall maybe meny things bad signal / interference etc what OS you running? are you using a router? how have you got them setup (ad hoc network?)
16 Dec 2006 at 23:38 #3 dunc dunc Soldato Joined 23 Oct 2003 Posts 2,755 Location Selma, Alabama Make sure that they are in g mode. If they are in b they will only connect at 11mbps. Plus check what Vent said Dunc
16 Dec 2006 at 23:42 #4 GeForce GeForce Soldato OP Joined 14 Feb 2006 Posts 4,644 Location Surrey, UK VeNT said: maybe meny things bad signal / interference etc what OS you running? are you using a router? how have you got them setup (ad hoc network?) Click to expand... Signal OK, I've put them literally next to each other for testing. XP Home on one, XP Pro on the other. Router is on the network, but not part of wireless. Yes, ad-hoc network. ---- How do I check/set their mode? I can't seem to find it Cheers, Jon Last edited: 16 Dec 2006
16 Dec 2006 at 23:51 #5 GeForce GeForce Soldato OP Joined 14 Feb 2006 Posts 4,644 Location Surrey, UK No worries, found the answer. Netgear products in Adhoc mode only support up to 11mbps Oh well, it's still usably fast Jon
