Hi all,
I just reactivated my Seti account, only crunching on my lappy atm as I work abroad a lot.
I have some parts I'd like to use and just build a dedicated rig, and not mess around too much with my main pc (sig) at home.
So I have the following lying in my cupboard at home (off the top of my head)
Mobo= Asus P6TD x58
CPU = i7 920 overclocked but can't remember what at
, on Titan Fenrir cooler
Mem = Corsair xms3 6GB 1600mhz Tri-channel
GFX = AMD 5870
SSD = Crucial Real M4 256GB
HDD = 1TB can't remember which !
PSU = Enermax Galaxy 1000W
Do I need to change anything out?
I'm not like hardcore folder but would like to have reasonable output. My main concern is my 5870.
1. Will changing this make the most significant change to output? If so then would would you guys recommend?
2. Do I need to use the ssd or just use the 1TB hdd?
3. As for clean install of OS, shall I just use Win7 or try Linux (I've never used or tried it before) I would try it if its not to much hassle to setup and does it make any difference to output?
Let me know what you experts think, I have around 400-500 quid available to make any changes.
Mobo= Asus P6TD x58
, on Titan Fenrir coolerMem = Corsair xms3 6GB 1600mhz Tri-channel
GFX = AMD 5870
You should be able to overclock to 4ghz without too much ado, while seti does use ati cards now it is still not as productive and cost effective as an nvidia card. There are lots of different projects that could utilise your ati card am sure someone will be along soon with more advice .... i am not upto scratch!
