Hi guys, I'm kinda back.... got myself one shiny new toy for my system (a 560, replacing a 260....)
so with the new card, mixed in with an old 295, i was just checking the results; and notice that my 295 is actually throwing up a couple of similar errors:
thats the output; I'm running lunatics unified installer 0.37 apps; was under the impression that mixing 560 and 295 shouldn't cause probs.
Any ideas?
Code:
<core_client_version>6.10.58</core_client_version>
<![CDATA[
<message>
Incorrect function. (0x1) - exit code 1 (0x1)
</message>
<stderr_txt>
setiathome_CUDA: Found 3 CUDA device(s):
Device 1: GeForce GTX 295, 895 MiB, regsPerBlock 16384
computeCap 1.3, multiProcs 30
clockRate = 1242000
Device 2: GeForce GTX 560 Ti, 1023 MiB, regsPerBlock 32768
computeCap 2.1, multiProcs 8
clockRate = 1800000
Device 3: GeForce GTX 295, 895 MiB, regsPerBlock 16384
clockRate = 1242000
setiathome_CUDA: CUDA Device 1 specified, checking...
Device 1: GeForce GTX 295 is okay
SETI@home using CUDA accelerated device GeForce GTX 295
Priority of process raised successfully
Priority of worker thread raised successfully
size 8 fft, is a freaky powerspectrum
size 16 fft, is a cufft plan
size 32 fft, is a cufft plan
size 64 fft, is a cufft plan
size 128 fft, is a cufft plan
size 256 fft, is a freaky powerspectrum
size 512 fft, is a freaky powerspectrum
size 1024 fft, is a freaky powerspectrum
size 2048 fft, is a cufft plan
size 4096 fft, is a cufft plan
size 8192 fft, is a cufft plan
size 16384 fft, is a cufft plan
size 32768 fft, is a cufft plan
size 65536 fft, is a cufft plan
size 131072 fft, is a cufft plan
) _ _ _)_ o _ _
(__ (_( ) ) (_( (_ ( (_ (
not bad for a human... _)
Multibeam x32f Preview, Cuda 3.0
Work Unit Info:
WU true angle range is : 1.138666
Cuda error 'find_pulse_kernel2<3, false>' in file 'd:/[Projects]/Berkeley/seti_cuda/seti_boinc/client/cuda/cudaAcc_pulsefind.cu' in line 1277 : unspecified launch failure.
Cuda error 'find_pulse_kernel2<4, true>' in file 'd:/[Projects]/Berkeley/seti_cuda/seti_boinc/client/cuda/cudaAcc_pulsefind.cu' in line 1293 : unspecified launch failure.
</stderr_txt>
Any ideas?
