Seti not requesting GPU work
14 May 2009
Since the servers have come back up I noticed the machine is requesting (and got a few) CPU work units but it is not requesting GPU work.
The messages shows
16-Jun-2010 22:31:04 [---] NVIDIA GPU 0: GeForce GTX 275 (driver version 25721, CUDA version 3010, compute capability 1.3, 896MB, 701 GFLOPS peak)
16-Jun-2010 22:31:04 [SETI@home] Found app_info.xml; using anonymous platform
when Boinc is started. The cudart.dll (or whatever it's called) exists in the boinc program files folder. Any ideas how I can kick in to at least requesting them?
I have the 257.21 display drivers installed and we're running on XP.
TIA
That looks fine, when I briefly ran Seti this morning it didn't get one GPU task, server was saying there were no tasks :(
The messages in Boinc don't show that the system is requesting any GPU work, unless I ask I don't expect to get. I can see messages requesting CPU work.
Check your options in Boinc manager, you might have it set not to use gpu. You can also snooze gpu from right clicking on the Seti manager icon, may have done that by mistake?
It shouldn't be the preference in Boinc manager as I set that to use GPU even if the PC is in use, just checked the right click on the icon and that's not checked :(
Any more ideas? Are there any checks I can do to ensure the Cuda files are present and correct? I'm using Lunatics optimized clients if that may make a difference.
No gpu work coming down here either so I convert the cpu work to gpu work with rescheduler.
Have it set on automatic so it runs every 4 hours, now I have loads of gpu work :)
The excerpt from the log file you posted is showing that the card is recognized and there so there is nothing wrong there.
Can you post a larger section of the log file?
Here is the complete startup sequence, there is no mention of GPU in the rest of the file.
16-Jun-2010 22:31:02 [---] Starting BOINC client version 6.10.56 for windows_intelx86
16-Jun-2010 22:31:02 [---] log flags: file_xfer, sched_ops, task
16-Jun-2010 22:31:02 [---] Libraries: libcurl/7.19.7 OpenSSL/0.9.8l zlib/1.2.3
16-Jun-2010 22:31:02 [---] Data directory: C:\Documents and Settings\All Users\Application Data\BOINC
16-Jun-2010 22:31:02 [---] Running under account *********
16-Jun-2010 22:31:02 [---] Processor: 4 GenuineIntel Intel(R) Core(TM)2 Quad CPU @ 2.40GHz [Family 6 Model 15 Stepping 7]
16-Jun-2010 22:31:02 [---] Processor: 4.00 MB cache
16-Jun-2010 22:31:02 [---] Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss htt tm pni ssse3 cx16 nx lm vmx tm2 pbe
16-Jun-2010 22:31:02 [---] OS: Microsoft Windows XP: Professional x86 Edition, Service Pack 3, (05.01.2600.00)
16-Jun-2010 22:31:02 [---] Memory: 2.94 GB physical, 4.78 GB virtual
16-Jun-2010 22:31:02 [---] Disk: 195.31 GB total, 146.13 GB free
16-Jun-2010 22:31:02 [---] Local time is UTC +1 hours
16-Jun-2010 22:31:05 [Einstein@Home] URL http://einstein.phys.uwm.edu/; Computer ID 1944950; resource share 1
16-Jun-2010 22:31:05 [SETI@home] URL http://setiathome.berkeley.edu/; Computer ID 4928760; resource share 100
16-Jun-2010 22:31:05 [SETI@home] General prefs: from SETI@home (last modified 22-Feb-2010 10:54:40)
16-Jun-2010 22:31:05 [SETI@home] Host location: none
16-Jun-2010 22:31:05 [SETI@home] General prefs: using your defaults
16-Jun-2010 22:31:05 [---] Reading preferences override file
16-Jun-2010 22:31:05 [---] Preferences:
16-Jun-2010 22:31:05 [---] max memory usage when active: 1503.49MB
16-Jun-2010 22:31:05 [---] max memory usage when idle: 2706.28MB
16-Jun-2010 22:31:05 [---] max disk usage: 2.00GB
16-Jun-2010 22:31:05 [---] don't use GPU while active
16-Jun-2010 22:31:05 [---] suspend work if non-BOINC CPU load exceeds 25 %
16-Jun-2010 22:31:05 [---] (to change preferences, visit the web site of an attached project, or select Preferences in the Manager)
16-Jun-2010 22:31:05 [---] Not using a proxy
Initialization completed
16-Jun-2010 22:31:05 [SETI@home] Sending scheduler request: To report completed tasks.
16-Jun-2010 22:31:05 [SETI@home] Reporting 8 completed tasks, requesting new tasks for CPU
16-Jun-2010 22:31:09 [SETI@home] Scheduler request completed: got 5 new tasks
16-Jun-2010 22:31:11 [SETI@home] Started download of 24dc09aa.14770.15200.16.10.170
16-Jun-2010 22:31:11 [SETI@home] Started download of 24dc09aa.14770.15200.16.10.171
16-Jun-2010 22:31:17 [SETI@home] Finished download of 24dc09aa.14770.15200.16.10.171
16-Jun-2010 22:31:17 [SETI@home] Started download of 24dc09aa.14770.15200.16.10.142
16-Jun-2010 22:31:17 [SETI@home] Starting 24dc09aa.14770.15200.16.10.171_0
16-Jun-2010 22:31:17 [SETI@home] Starting task 24dc09aa.14770.15200.16.10.171_0 using setiathome_enhanced version 603
16-Jun-2010 22:31:19 [SETI@home] Finished download of 24dc09aa.14770.15200.16.10.170
16-Jun-2010 22:31:19 [SETI@home] Started download of 24dc09aa.14770.15200.16.10.165
16-Jun-2010 22:31:19 [SETI@home] Starting 24dc09aa.14770.15200.16.10.170_1
16-Jun-2010 22:31:19 [SETI@home] Starting task 24dc09aa.14770.15200.16.10.170_1 using setiathome_enhanced version 603
16-Jun-2010 22:31:20 [SETI@home] Finished download of 24dc09aa.14770.15200.16.10.142
16-Jun-2010 22:31:20 [SETI@home] Started download of 17dc09ac.19671.11110.11.10.194
16-Jun-2010 22:31:20 [SETI@home] Starting 24dc09aa.14770.15200.16.10.142_1
16-Jun-2010 22:31:20 [SETI@home] Starting task 24dc09aa.14770.15200.16.10.142_1 using setiathome_enhanced version 603
16-Jun-2010 22:31:20 [SETI@home] Sending scheduler request: To fetch work.
16-Jun-2010 22:31:20 [SETI@home] Requesting new tasks for CPU
16-Jun-2010 22:31:22 [SETI@home] Scheduler request completed: got 0 new tasks
16-Jun-2010 22:31:22 [SETI@home] Message from server: Project has no jobs available
16-Jun-2010 22:31:23 [SETI@home] Finished download of 24dc09aa.14770.15200.16.10.165
16-Jun-2010 22:31:23 [SETI@home] Starting 24dc09aa.14770.15200.16.10.165_1
16-Jun-2010 22:31:23 [SETI@home] Starting task 24dc09aa.14770.15200.16.10.165_1 using setiathome_enhanced version 603
16-Jun-2010 22:31:27 [SETI@home] Finished download of 17dc09ac.19671.11110.11.10.194
16-Jun-2010 22:31:37 [SETI@home] Sending scheduler request: To fetch work.
16-Jun-2010 22:31:37 [SETI@home] Requesting new tasks for CPU
16-Jun-2010 22:31:39 [SETI@home] Scheduler request completed: got 0 new tasks
16-Jun-2010 22:31:39 [SETI@home] Message from server: Project has no jobs available
This was from yesterday and because it was not requesting GPU work I changed the local pref to use GPU always. I've just restarted BOINC and will check for differences but I don't expect any as the above was after a restart as it wasn't asking before for GPU work and I wondered then if it had got confused.
Oh dear, I hope it's not me the aliens use as a benchmark for average human intelligence as I fall well short.
Code:
P - Problem
I - in
C - chair
N - not
I - in
C - Computer
Why are they still producing Win98 versions of the Lunatics apps so idiots like me can download the wrong one :o Hopefully now I've got the Win32 one it may work better.
This is what I'm getting
18/06/2010 10:32:35 SETI@home Requesting new tasks for GPU
18/06/2010 10:32:37 SETI@home Scheduler request completed: got 0 new tasks
18/06/2010 10:32:37 SETI@home Message from server: Project has no jobs available
18/06/2010 11:55:36 SETI@home Sending scheduler request: To fetch work.
18/06/2010 11:55:36 SETI@home Requesting new tasks for GPU
18/06/2010 11:55:39 SETI@home Scheduler request completed: got 0 new tasks
18/06/2010 11:55:39 SETI@home Message from server: No work sent
18/06/2010 11:55:39 SETI@home Message from server: No work is available for Astropulse v5
18/06/2010 11:55:39 SETI@home Message from server: Your app_info.xml file doesn't have a usable version of SETI@home Enhanced.
18/06/2010 11:55:39 SETI@home Message from server: (reached daily quota of 143 tasks)
No GPU work:( no recent CPU work either due to one WU sending the completion time up to 15 hours+:eek: So how do I get to exceed my daily quota when no work sent:confused::confused:
Obviously some thing wrong at B0rkeley & a glitch in the server upgrade.
Time will tell. I don't think it's your setting Picnic.
Does sound different, mine was caused by me installing the wrong version of Lunatics app. Just checked again and one Cuda task in progress but still only one in the queue. Only about 15 CPU tasks queued as well. That'll all get exhausted mighty quickly when B0rkley goes down again at the weekend.
