Setting 2600k CPU affinity in Shortcut text...?
16 Oct 2007
Here's the Issue, hopefully a Windows boffin can advise on the solution :)
Windows 7 x64 running 3D software.
2600k set with HyperThreading On.
I run Lightwave 3D which has two separate programs in it.
One program (the modeller) only uses a single CPU core, the other (renderer) takes advantage of all the cores available in 2600k, 8 with HT.
Been reading up on Hyperthreading/Core Parking in Windows 7 and its better performance wise with my single core program to disable all virtual cores.
Core parking is good in this case.
I have been setting CPU Affinity for the program's process in Task Manager, but is a pain in the butt to have to do that every time I restart the program.
I think you can amend the Shortcut for the program to have a command that sets affinity every time the program is run?
Thanks for any help. :)
you create a batch file with something like
start "" /D"path to exe" /AFFINITY [hex affinity] exename.exe [parameters]
in it
open a dos window a type
start /?
to show help for start command
Hi, thanks for the reply.
It wasn't so much the processer priority I was looking to set though (Right click process in Task manager - Options to set priority(no) or Set Affinity(Yes) , but which CPU cores were activated when i ran the program with the amended shortcut link?
Sorry if I've misunderstood your reply. :)
thanks.
C:\Windows\System32\cmd.exe /C start "" /affinity 1 "path to your program"
You could try that as your shortcut, that would start program using only CPU 0.
thanks.
No worries I shall explain
^this bit is where you set the affinity for the program you are running
AFFINITY , is which CPU core to run something ON
