Setting a Virtualbox machine to start on first boot..
Don
21 Oct 2002
Parts Unknown
Does anyone know how to do this?
On the host machine, it's got autologon, I want it to start up Virtualbox and then start a specific machine
is there a bat file command you could strike up pointing to the virtualbox.exe and the name of the vm config to start? Then drop that in the startup folder?
Got it.. found it in the help file
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" startvm MACHINENAME
another handy one..
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" controlvm MACHINENAME savestate
That save's the current state for a super quick resume, I've added that to the shutdown batfile for the host machine
bledd.
How I did it left me with a slow boot, because it still boots up as per windows, and the then boots up your OS in VirtualBox. But here goes,
Start VirtualBox,
Right Click on the OS you want to boot from,
Select Create short cut to desktop,
Then place the short cut in your Startup Folder.
Again it worked for me, but with a slow boot. Someone might come along with a faster idea.:)
