- 20 Oct 2002
- London
I’m guessing this is the appropriate forum for this question, although I’m not planning on overclocking at the moment, I just want to get it working.
I’ve just received the bits for my upgrade which includes a new mobo and CPU and I’ve been looking through all the documentation. I’ve got an Athlon II X3 450 3.2 GHz which I believe needs a x16 multiplier. According to the mobo manual, in the JumperFree Configuration of the Advanced menu the Processor Frequency Multiplier is set to 'Auto'. The manual options only go up to 'x15.0 3000MHz'. Does this mean I need to upgrade the BIOS to get support for x16?
Of course, the manual is dated Dec 2009 so it is possible the BIOS is already a later version, and the manual also says that the items and configuration options may vary depending on the AMD CPU type, so I might find when plug it all in and switch it on there is a x16 option.
I’m assuming that if there is only a x15 option the CPU will still work but will be ‘underclocked’. Is that correct?
