Ok, want to start pushing my system a little. E6600 at present at 2.8, and 6400 Ram at 667Mhz 5,5,5,12 on an Ausus P5W DH. Bios 903.
What do I need to do to get ram to 800, 4,4,4,12. I can see settings for the 4,4,4,12 but the settings in DDR only have odd numbers like 667, 772, 827?? Which one of these shall I select 772 or 827?
also, can someone explicitly state what voltages to change and to what? can't seem to find a vdimm setting to set at 2.1 volts (I presume?)
If I push the E6600 to say 3.2, at present vcore says 1.95 volts, should I increase this a little too?
cheers for any help, Am
), tried 340 for the CPU no post, so can't get the Ram to 400... hmm...would I need to increase voltage on the CPU to up it a little? I was wrong before, the CPU is running at 1.32....
