Setting for new games
16 Jun 2008
my PC configuration is:
nVidia GTX 550ti
Asus P5Q
Intel Q6600
4GB RAM
i have some new games but i'm not getting a good performance on above system. could you please advice me, how can i run these games smoothly. i'm not in a position to buy any new hardware. all i need to find the best setting for all these new games.
these are the games:
FarCry 3
Crysis 3
MOH Warfighter
COD Black Ops 2
Sounds like something is wrong, the 550 ti isn't a great card but should be able to run those games without 'freezing'.
Are all the drivers installed?
And if your settings are too high try reducing them. Reduce anti aliasing, post processing and shadows. That won't ugly things too much.
i am using high res. with all other setting to high.
ok... i will try to keeping bringing it down unless i get the smooth frames.
but as i noticed before, i was failed in MOH warfighter even when i brought it down to low.
going to update my gpu driver which was released 3 days back. then i will start from min res and lets see what result i get.
GPU driver is updated.
all set to med.
res is 1920x1080
crysis is now playing perfectly
also found some new patches for these games.
i will try the same for other games
