Hi,
I was trying to set raid 0 up on my DQ6, it worked and i got windows installed but when in windows it kept hanging when try to make and format my other partitions. This was on the Intel controler and then tryed the same drives on the gigabyte controller with the same disks and a new windows install. And the same thing happend. I used the discs fine on the nforce raid contoller in raid0. But now i think on of my samsung 80GB drives has died... everything works fine with 1 disc.. although its a bit slow.
. Thanks.
