Setting up 3 monitors
26 Dec 2008
Can anyone give me some advice?
Ive just ordered 3 monitors so I can start using my computer on a desk instead of having it connected to my tv.
How would I connect them to my pc?
Would I use 1 port on my graphic card and a splitter device to connect all 3 monitors to the same port?
Or would I connect each monitor to a different port?
my graphics card has 1 hdmi an 2 dvi ports.
I have never had multiple monitors so I need some advice.
Thanks
Can you connect three monitors to a GTX460 and have them work? I though you'd need an additional GPU.
A single AMD card would obviously not be a problem assuming DisplayPort is used for one of them.
Thanks IronWarrior.
An I am not 100% sure if the one GPU will work to be honest, I have been considering buying a cheap used GTX 460, I could get one for about £75 now.
Does anybody know if a single GTX 460 can run 3 monitors? (maybe I should ask that in the GPU section)
I dont really need a lot of GPU power because I dont use my PC for gaming I just want the triple monitor setup for my uni work.
