I am needing to extend my wireless signal at work. I tried the Powerline adapters but due to the old wiring etc were next to useless. I have purchased 2 x Ubiquiti Unifi AP's. These came with PoE adapters so quite simple to run cabling for.
Wiring is straight forward i think. I shall be connecting both via separate cables to the BThub5.
Now what I am unsure of:
We have several handheld devices that connect throughout the building that I would like to roam. I want them to select the best signal rather than wait until they lose signal. From what I have read, I should set the same IP address for the hub and the WAP's (such as 192.168.1.200?), then select channels 1, 6 and 11 that should be in the settings? I could be completely wrong however. haha
Thank you for any help you can give.
