Setting up a forum
Caporegime
1 Nov 2003
Lisbon, Portugal
Hi All :)
Got my website how I like it now, still got to play about with the gallery to get the pictures categorised but regardless...
I want to setup a forum on there, I have no idea about this stuff so if anyone can recommend anything that'd be great.
Many Thanks.
Jacob.
you must upload and install one, Depending if you want a free forum eg ones you can install in cpanel. Or you can pay for vBulletin or IPB, There the ones i know. vBulletin and IPB both cost money. I suggest you take a look at some free ones! Its basicly uploading Cmoding and then installing. Then you config in a admin pannel. Its very simple. If you would like more instructions add me on MSN.. In my profile
Phil
masslac said:
Because it's good and free, obviously.
well, all i can see is a very bland and feature-lacking messageboard. so if the best argument in it's favour you can come up with is "it's good and free" then i suggest people don't bother with it and look up SMF and phpBB instead.
Why PunBB?
The idea of PunBB was first born when I needed a discussion board for a website I was working on. After an exhaustive search, all the boards I found were either over-featured or too graphic for my needs. I wanted a package that
was fast.
had a simple layout and design.
was easy to administrate and moderate.
didn't output huge, non-valid, (X)HTML pages.
had source code you could read and understand.
To my dismay, such a forum was nowhere to be found. Thus, I started working on PunBB, or just Pun as it was called back then.
Developing software to "please the masses" isn't difficult. Just cram in every possible feature you can think of and most people will love it. Some people, however, will hate it and look for alternatives. The problem with developing for that other group of people is having to make decisions on whether to implement a feature or not. What is a "must-have" and what is not?
Some features that I have so far chosen not to implement are: private messaging, file attachments, polls, linking to off-site avatars, advanced text formatting controls, subforums etc etc. The jury is still out on some of these features, but don't expect them to pop up anytime soon. It should however be noted that most, if not all of these features have been realised in the form of third-party mods.
another vote for punBB, light easy to use and very customiseable, SMF is good, phpbb, unless you want your site hacked then go for it otherwise its too risky
SMF is better than most and better than IPB imo. I set mine up, heres the link Forums. Putting a portal on is very easy too its bit like a full working CMS and no spammers so far :).
