So I have a few new parts to build a new rig.
Have new:
Ryzen 5 3600
Msi B450 Max
2x8GB Ddr4
Existing:
Samsung evo ssd
750w psu
Max tower
Im sure I'm going to run into technical problems so wanted to double check on the correct order/procedure to set up everything.
Going to put all parts together for new rig, have windows 10 installed onto USB with product key ready written down.
Is it a case of just putting everything together then firing it up and inserting usb to install Windows.
Windows 10 is already on the ssd but am I better off booting up the USB and then connecting the ssd later once I'm in? Or connect ssd first? Will the new mobo/cpu recognise windows 10 from the ssd?
Any advice would be appreciated.
Thanks
Have new:
Ryzen 5 3600
Msi B450 Max
2x8GB Ddr4
Existing:
Samsung evo ssd
750w psu
Max tower
Thanks
